Time to make two flap control rods. These are aluminum tubes tapped for 8/32 threads for the rod end bearings. The aluminum tubes are cut to 6.5", each end tapped carefully, and tested for the rod end bearing attachment.
The length may have to be adjusted a bit depending on flap fitting and it's travel requirement.
