Brief Description: Fitting the Wing Bell Cranks/Aleron Brackets
Fitting the Wing Bell Cranks and Aleron Brackets. The bell crank will connect two torque tubes, one going to the Aleron, the other going to the Fuse to connect with the control column.
All of the control surfaces in the RV-8, except the rudder, are connected via torque tubes, which provide very responsive handling to pilot inputs. The 2nd pic demonstrates...
