My RV-8 Build Log
RV-8
Markings, Placards a
7-23-2019
Aircraft Data Plate
Located and installed the aircraft data plate. Kept is simple with just the FAA required information, made sure it matched exactly the aircraft registration.
Installing the Data Palte
Installed
Kinda hard to read with this lighting
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
