My RV-8 Build Log
Date:  9-8-2016
Brief Description:  Backup Battery Relocation
While working on the right side console, realized I was not going to be happy with the clearance (or lack thereof) from the wiring harness and the backup battery. I decided to move the backup batter inboard so there would be sufficient clearance to prevent the wiring harness from chafing against the battery.
I drilled out the blind rivets securing the battery brackets to the cabin floor, then used the brackets to match drill two new rivet holes in board, shifting the brackets inboard. Riveted the brackets to the cabin floor, which is now ~ one inch more inboard, giving plenty of clearance for the wiring harness.
GLD39R Brackets
GLD39R Brackets
Too Close
Too Close
Backp Battery Mounting Bracket
