My RV-8 Build Log
RV-8
New Baggage Door Build Part 2
Continued with the new baggage door build. Strapped the door with ribs to the fuse while clecoed, then final drilled each hole to #40. Removed and disassembled, deburred each hole, then dimpled the skin and ribs as required.
Baggage Door #3 (I think)
New Baggage Door Fitment
Skin Dimpeled
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
