My RV-8 Build Log
Date:  10-15-2017
Number of Hours:  5.00
Brief Description:  Emp Fiberglass Work Continued..
More filling and sanding of the elevator fiberglass fairings. While the epoxy/microballons set up, started working on the HS fiberglass fairings where the fairing covers the leading edge of the elevator counterbalance weight. A balsa block is used to provide backing got adding the epoxy and microballons mixture.
More fill and sanding for the elevator fairing
Balsa block and initial fill and sanding
Somewhere closer to the end than the beginning
