My RV-8 Build Log
Date:  8-1-2017
Brief Description:  Right Wing Tip Landing Light Adjustment
Decided to attempt to relocate the landing light to see if I could move more outboard. There is plenty of room if I somehow get the light closer to the wing tip fairing where it is mounted, One way to accomplish is to move the bracket mount to the interior of the wing tip fairing, which pulls it back toward the wing tip fairing, allow it to move outboard a bit more as well.
I marked and then removed sufficient wing tip material to allow for the top portion of the bracket to pass through from the interior, used the same holes previously drilled for the mount screws required for the bracket.
it is better, but, I am still not really satisfied with the overall look.
Landing Light Relocation
Mounting Bracket Moved to Interior Mount
Slight Improvement in Alignment
