My RV-8 Build Log
RV-8
More Sanding of Canopy Skirts
More sanding of the canopy skirts, trying to identify all the areas that need attention, perhaps a thin layer of micro balloon/epoxy mix, and more sanding. Using 220 paper now to sort out where more attention to detail is needed.
Sanding with 220
Joint of left and right side
Little bump up to cover canopy rail
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
