My RV-8 Build Log
RV-8
Connecting the Kavlico Sensors
Routed the shielded wires from the GEA24 to the Kavlico pressure sensors for Fuel, Oil and Manifold. Used butt splice to connect to each sensor. I'll be doing something for strain relief as soon as I sort out what that will be...
Kavlico Sensor Wiring
Butt Splice Connector
Oil Pressure, Fuel Pressure and Manifold Pressure
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
