My RV-8 Build Log
RV-8
ELT Remote Switch Install
Time to cut a rectangular hole. To make sure it looks like it is supposed to, I drilled this out from the panel side.
• Clecoed the template in place on the forward side, and taped around the template to keep from accidentally scratching else.
• Used #40 bit to drill the perimeter of the template - yes it looks quite ugly.
• Followed the #40 with #30 to connect the holes enabling removal of the unwanted material to reveal a very ugly rectangular hole.
• Proceeded with filing smooth(er) the rectangular hole until the remote ELT switch fits and the four screw hole align properly.
Template ready for cutting panel
That is UGLY !
That's an improvement
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
