My RV-8 Build Log
RV-8
Comm and Xponder Antenna Installation
Located and installed the doubler plates for the Comm 1 and 2 antennas, and the transponder antenna.
The transponder antenna needs to be as far away from the ELT antenna as possible... I don't know yet where the ELT antenna is going...
Comm Antenna doubler plate in place
Transponder Antenna doubler plate
Doulber plates ready to rivet
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
