My RV-8 Build Log
Date:  8-17-2014
Number of Hours:  4.00
Brief Description:  Rudder Bottom Cap Fitting
While fitting the rudder bottom cap, I realized the holes drilled to attach the fairing to the bottom of the rudder have been, well, drilled rather randomly, not in a straight line, and not evenly spaced. No rivet spacer was used here!!
I can't leave this alone... Decided to fill the existing holes and drill new holes.
• Filled the existing holes, and then re-measured for new holes.
• Located the new holes and match drilled to the rudder bottom flange.
• Using a nut place jig tool, located the holes for nut plates so I can fairly easily remove the fairing should it be necessary since the tail light wiring will be inside.
• Deburred the new holes, and dimpled the #40 holes for the AN426 rivets to hold the nut plates.
• Riveted the nut plates in place using AN426 rivets.
• Fitted the rudder bottom cap fairing on to the bottom of the rudder. I am planning to use AN6R8 screws and tinnermans for attaching the fairing
Old rivet holes filled
New rivet holes drilled
Rudder bottom cap fairing test fitted
