My RV-8 Build Log
RV-8
Wiring Connections to SCB/CB
• Marked the SCB/CB locations with wire identifiers, and then began connecting the ring connectors to each SCB or CB as indicated in the wiring plan.
• Identified the wires and marked the locations of the ground and power distribution, connected corresponding wires - did not yet secure.
• Pulled all remaining wired of the harness to the wing roots for lighting, and to the boost pump.
• Remaining wiring, there are a few wires to build for the avionics and elevator trim motor...
• In the process of completing the panel install of the G3X stuff and associated do dads.
SCB / CB Connections
So far, so good...
Much Lighting Required for this work
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
