My RV-8 Build Log
RV-8
Engine Baffle Install - Oil Cooler Cut Out
• Used a unibit to drill 1" diameter holes in the corners of the marked cut out location on the aft left baffle panel for the oil cooler.
• Used Dremel to remove the remaining panel, cutting wheel and also smoothed edges to mostly straight lines !
Step 1 - Unibit the corners with 1" hole
Used Dremel to remove remaining
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
