Brief Description: Engine Baffle Install - Left Aft Baffle and Oil Co
The aft baffle left side is made up of several components to include the oil cooler mount.
• Identified the components, clecoed the aft and left side baffle. There is a spacer that goes between these two, left off for the moment. • Attempted to locate the oil cooler doubler plate on the aft side of the baffle where the oil cooler will be mounted. Figured out this will require a bit more sorting before cutting the hole in the aft baffle. • Clecoed the oil cooler support bracket to the aft and side panels, just to get the picture of how this goes together.
The exact location of the oil cooler support bracket and doubler plate is TBD
