My RV-8 Build Log
RV-8
Prep the Canopy Plexi and Skirt for Riveting
After final drilling the plexi bubble using a unibit to a size acceptable for the grommets, inserted the grommets into each hole in the plexi bubble.
Countersinked the #30 holes in the canopy skirt for accepting the CS4-4 and ACQQ4-4 rivets.
Tested several times the countersink setting since this is fibreglass, and I have never countersunk fibreglass before.
Inserting the grommets
countersinking the CS4-4 and ACQQ4-4 rivet holes
Tesing the countersink setting...
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
