My RV-8 Build Log
RV-8
Canopy Plexi Fitting and Drilling
Time to place the canopy bubble back in place, cleco the keeper rivet holes, and pre-drill the ACQQ4-4 holes using a special bit just for plexiglass.
Carefully drilled each hole in the plexiglass bubble and clecoed as progress was made.
Canopy frame final drilled
Plexi bubble in place
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
