Getting the two halves of the fibreglass canopy skirt to meet is, well, fun...
Used several iterations of duct tape to make sure the skirt stays where I want in order to make a template for a doubler plate I will use to join the two halves of the canopy skirt.
Inserted the template under the fibreglass skirt and carefully pre-drilled two #40 holes through the skirt to mark the template. Eventually, the doubler will have three holes and CS4-4 rivets per side.
