Brief Description: Brake Line - Mounting Bracket to Master Cyllinders
The low pressure side of the flex brake line is now mounted from the Nylon Tee to the Mounting Bracket Plate on the Forward fuse baggage compartment, and routed to the brake master cylinders.
DG4 clamps are offset a bit to counteract the natural bend in the flex line so they do not contact the metal flex lines on the hight pressure side of the master cylinders. Left enough flex line to move the rudder/brake pedals back one, possibily two settings as these are the ground adjustable rudder pedals.
The brass fittings require quite a lot of tightening to secure th flex lines to prevent brake fluid leakage.
