Brief Description: Installed Connectors in lower gear leg tower skin
Installed the left and right brake line connectors on the bottom fuse skin. First, located the holes to be drilled by measuring distance used for the Fuel Vent Line, and a little estimation. Drilled the holes using step drill. Fitted the 90 degree elbow connectors from the bottom side, used AN960 washer as spacer on top side, then retaining nut to hold in place.
Spent 1.5 hours planning, 30 minutes doing...
Left Gear Leg brake Line Conneector, Fuel Line and Fuel Vent Line in view
Right Brake Line Connector in Gear Leg tower, Fuel Vent Line in view
