Making the fuel line from the airflow filter to the electric boost pump. Not there yet. The line must traverse through the left gear leg tower. Of course the holes in the tower don't line up with the filter or boost pump. Anyways, made a template from twisted garden wire, which was nice, if not very helpful. First real attempt turned out about an inch short on the filter side. Second attempt is much better, might in fact work if I can tweak it just enough to clear both holes in the gear leg tower, and not touch. Can't have the fuel line rubbing the gear leg tower...
a whole lot of trial and error...
First attempt, a bit mangled and short, but basic alignment is correct
Second attempt, fits, just needs a little tweaking to ensure gear leg tower clearance
