My RV-8 Build Log
Date:  4-22-2012
Manual Reference:  82
Brief Description:  Right Tank Fuel Line Valve to Wing
Formed and installed the right fuel tank line (valve to wing). Used twisted garden wire to form the dimensions and bends, then used as a pattern for bending the 3/8" aluminum tube. Worked amazingly well, first time go, which is a big contrast to the difficulty in forming the fuel valve to fuel filter line, which requireed 2 weeks and 8' of tubing !
I will probably re-work the first bend from the fuel value. Currently it is a 90 degree bend to the cabin floor, but might look better as 2 x 45 degree bends.
Fuel Line bent for Right Fuel Tank
Right Fuel Tank Line installed
Mated to Fuel Valve
Mated to Fuel Valve
