My RV-8 Build Log
RV-8
Making Rudder Stops and Installl
Rudder stops fabricated (twice - first set was just a bit too short length-wise.) I wanted to match the rivets with the rivet line in the fuse to ensure all the internal bits were center-drilled.
Right Rudder Stop
Left Rudder Stop
Right Rudder Stop installed
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
