My RV-8 Build Log
RV-8
Attaching the HS and VS to Fuse
Attach the HS and VS to the Fuse. Ensured the HS is alinged to fuse with tolerance called in spec. VS has 3/16 shift per spec from front to back (leadng edge centered, trailing edge is not.)
Centered, drilled and bolted
3/16 shift to right
HS and VS attached
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
