My RV-8 Build Log
Date:  4-12-2011
Number of Hours:  5.00
Brief Description:  Fitting the Wing Bell Cranks/Aleron Brackets
Fitting the Wing Bell Cranks and Aleron Brackets. The bell crank will connect two torque tubes, one going to the Aleron, the other going to the Fuse to connect with the control column.
All of the control surfaces in the RV-8, except the rudder, are connected via torque tubes, which provide very responsive handling to pilot inputs. The 2nd pic demonstrates...
Wing Bell Cranks
Wing Bell Cranks
What is supposed to happen
Aleron Brackets
Aleron Brackets
