Brief Description: Bead Blasted Brake Linkage Parts - Flap Arms
Bead blasted rudder pedal brake linkage arms (were painted black, will be powder coated white). Also bead blasted the two flap actuator arms that a shorted to convert from manual plain flaps to electric plain flaps.
I also glued the new UHMV plastic strip to the nose gear leg. I used 3M DP110 epoxy for this. I used the nose gear friction collar to clamp the strip to the nose gear leg while the glue sets up.
