Another 2 ply lay-up this time not vacuum bagged. If this lay-up comes out good I will use it for the upper aft fuselage bulkhead.
I also used a scanner at work to copy one of the template drawings. From the copy I cut the patterns for the aft fuselage bulkhead (I glued the patterns to file folders before I cut them out). I also glued the stabilator cut-out pattern and the firewall upper cowl profile to a piece of 1/8 masonite. I will cut these out on the bandsaw.
