Brief Description: Trimmed Lay-Up - Layed-up Another 2 Ply
My lay-up from last session came out perfect. I cut four upper and four lower engine mount reinforcements out of the laminate. I also cut out two triangular gussets which will be used as mounting tabs for two angles that strengthen the rudder pedal center mount. I used our sheet metal foot shear to cut these parts because all the edges were straight. I also marked out the upper aft fuselage bulkhead and rough trimmed it with some hand sheet metal shears.
I made another 2 ply laminate which I will use for the lower aft fuselage bulkhead if the laminate passes QC!
