Bill's Glasair Odyssey
Date:  8-14-2007
Number of Hours:  1.25
Brief Description:  Bead Blasted Brake Linkage Parts - Flap Arms
Bead blasted rudder pedal brake linkage arms (were painted black, will be powder coated white). Also bead blasted the two flap actuator arms that a shorted to convert from manual plain flaps to electric plain flaps.
I also glued the new UHMV plastic strip to the nose gear leg. I used 3M DP110 epoxy for this. I used the nose gear friction collar to clamp the strip to the nose gear leg while the glue sets up.
brake linkage arms
brake linkage arms
Flap actuator arms
Flap actuator arms
