Bill's Glasair Odyssey
Date:  8-15-2007
Number of Hours:  0.50
Brief Description:  Pre-Cures for master cylinders
I am finally getting up the courage to start some lay-ups. I cut out some bid cloth on the 45 for laying up the master cylinder upper mounts. Basically I will lay up a square 2 ply laminate on a sheet of plate glass. The mounts will be cut from the resulting square pre-cure. Clearly I don't need these pieces now or even soon. I am just looking for something to practice on and get a feel for the resin system. In the past I have worked with regular epoxy or pre-pregs so I am sure there is a learning curve. I will vacuum bag this lay-up also just for practice. Stay tuned...
