Fit and drilled the Right-side Lower Access Panel on the boot cowl.
Since I have now mastered the fitting and drilling of this panel on the left - I decided to apply that expertise to fitting and drilling the panel on the right. It did go a lot faster on this one.
Now I only have to fit the nutplates and prime the parts so I can put them together.
Then I get to drill and dimple the boot cowl pieces around the firewall for the countersink nutplates and flush #8 screws. And then drill and attach nutplates to the rear bulkheads and intrument panel for the boot cowl to be attached.
