Brief Description: Installed second rear floorboard
Installed the second cargo-area floorboard.
This one went in just like the first. Only trick was that the holes for the rear seat mounting eye-bolts had to be drilled to fit, and I had to clean the threads in the fuselage for these before they would go in. The tapping took some time since you can't go very fast - about a quarter turn at a time. You definitely wouldn't want to break a tap off in the fuselage!!
Otherwise the nutplates and drilling was the same.
