Brief Description: Measured for Brake bolts and placed order.
Measured the thickness of the brake caliper torque plate used for mounting the calipers on the axle, and thickness of the mounting flange welded on the axle. Both are 0.125" - so the bolt needs a grip length of 0.25". Since the torque plates came with 3/8" to 5/16" hardened steel bushings that are to be used, I will use AN5 bolts. Available bolts are 3/16" (-5) or 5/16" (-6) grip length, so I will use the AN5-6A with washers.
Checked on close-fit stop nuts for this application, MS21042-5 should work.
