Received the Grove 6" Wheel & Brake kit, and the 1/16" SS control cable today.
Inspected the kit and test-fit the wheels on the landing gear. Everything looks great, and the wheels are a good fit. I am using the Grove 66-152 kit, which is the 60-1A wheel and the double-piston brake calipers.
Mounting the torque plate for the brake calipers will be a small challenge. The landing gear tubes are welded very closely to the mounting flange, not leaving very much room for bolts & nuts.
