EAA Chapter 24 Kitfox
Date:  12-11-2019
Number of Hours:  6.00
Brief Description:  Wing locker finish work
The stiffening angles have been permantly riveted to the wing locker doors. It was a learning process and a few of the rivets had to be drilled out and re-installed, but that was a great learning process as well! Next the cam locks need to be installed, and the hinge needs to be permantly riverted (or screwed) onto the wing.
Drilling out poorly installed rivet
Another not so hot rivet had to go
no more clecos to hold the stiffening angles on!!!
