Placed the lower engine shrouds on and then the engine mounting hardware. NOTE; lower two shroud pieces need to be installed prior to mounting the engine Leveled the engine. Placed the cooling fan on top and tested flange with dial gauge. Was .0027 tolerance when measured on top of the fan housing and .003 when measured on the bottom of the gear ring. This give a total runout or .0052 and .006. MAX ALLOWED .008
