Today I finished mounting the second tire and packing the second set of wheel bearings. I also prepped both wheel pant attach brackets by finishing the edges.
Then I bolted on the left wheel/tire and brake assembly to the left gear leg in order to test-fit everything. Pretty exciting!
The left gear leg with wheel, tire and brake installed.
Closeup of wheel, tire, wheel pant mounting bracket, and gear leg.
