Brief Description: Battery box; systems re-installation
Clecoed the battery attach angles to the battery box, then held it up to the firewall to see what the best location for mounting it might be. I also cut a section of 0.63" angle that will be attached to the backside of the firewall. The top three AN3 bolts will go though this.
Since all the interior paint is dry, I also re-installed the smoke oil line and rudder cables through their bushings in the floor supports and spar.
