Brief Description: Systems installation (flaps, servos); svc bulletin
Continued installation of various components:
-- Riveted in the slide tube guide for the aileron trim servo. -- Riveted in the attach bracket for the autopilot roll servo. -- Measured for the fuel lines, fuel vent lines, and brake lines. -- Planned for the wiring routes through the bulkheads and wing spar. -- Re-installed the flap motor and actuator arm/blocks. Complied with Van's Service Bulletin (drilled and safety-wired the flap motor shaft.)
Flap motor arm safety-wired. Note cupped washers to help prevent excessive rotation of the rod end.
