Continued re-installing various systems and components: -- Clamped the plastic anti-chafe covers into position where the cables exit the fuselage at the tail. -- Riveted the aileron trim servo tray into the fuselage. -- Installed the rudder cable forward attach clevises to the firewall. -- Planned the routing of wiring harnesses forward and aft through the bulkheads. -- Prepped lower longerons for installation of the flap actuator arm and attach blocks. -- Attached fuel selector to its attach plate. -- Shot a second coat of paint on various small components. -- Finally, I pulled out and organized all the various bags of hardware that will be needed as the interior goes back together (Photo 3).
