Buck's RV-8
Date: 4-9-2008
Number of Hours: 3.00
Brief Description: Rudder pedals, aileron trim
I began by re-riveting the rudder pedal slider-latch mechanism. Now it's straight as an arrow.
Next, I began fabricating the components of the aileron trim assembly, starting with the servo pushrod. I used a bandsaw to make the first cut of the slot, then used a series of files to open the slot up to 1/8". I used the drill press to make the three required #30 holes in the tube.
The builder's manual says not to use a drill bit to open up the hole in the plastic bushing where the aileron trim push tube will go. It recommends using a Dremel tool instead. I started doing this, but decided to sacrifice a bushing as an experiment. Wouldn't you know, a series of larger and larger drill bits running very slowly in an electric drill worked beautifully. I held the bushing with a pair of padded pliers.
Finally, I prepped and primed the servo mount, the pushrod support bracket, and the pushrod (except for the bottom 2" of the rod you can't see in the photo...)
The rudder pedal slider-latch mechanism, ready for installation.
The aileron trim pushrod, pushrod support bracket, and servo mount, after priming.
