Buck's RV-8
Date: 1-28-2008
Number of Hours: 5.50
Brief Description: Avionics access door; rear cockpit map light
I spent a very satisfying four hours cutting a big hole in my airplane. In this case, it was the large access door that will allow access to the back of the instrument panel from the forward baggage compartment. I drilled the mounting hinge and spacer strip to the bulkhead, and also to the door, then removed them and began cutting the bulkhead with a Dremel tool. Once that was done, I filed the edges of the resulting hole to within about 1/8" of the cut-line. I clecoed / clamped the door in position, and cut the hinge pin and formed a bent handle on one end of it. The door will be secured with #8 pan-heads screws and platenuts. I thought about installing camlocs, but for the number of times I'll have to open this door, there's no sense going to all that trouble.
Next, I measured, marked, and cut out a rectangular hole next to the rear seat map-light hole for the on/off rocker switch. I'll have to enlarge the hole slightly for the best fit of the switch.
Front view of the avionics access door.
Closeup of the access door hinge. Not shown is the spacer strip under the lower hinge section.
Rectangular hole is for the maplight switch.
