The first thing I did this evening was finish installing the platenuts on the forward floorboard and the front seat pan. There are still some more platenuts to be installed in the floor structure itself.
Next, I designed and fabricated an attach angle and a strker plate for the two flap microswiches. The angle will be bolted to the bulkhead just aft of the flap motor, and the striker plate will be attached to the flap arm. When the flaps are up, one of the switches will cut off power to the "up" part of the flap circuit so the flap motor shuts off, and the other switch will signal the trim system to go to "cruise" mode (which will lower the sensitivity of the trim at higher airspeeds).
At about this time, I ran out of fuel for my shop heater. It got cold pretty quickly in there.
The last of the platenuts have been installed in the floorboards.
The placement of the two microswitches on the mounting plate.
The assembly on right will be attached to the flap arm; the switches will be on the nearby bulkhead.
