I received my flight-adjustable rudder pedal kit from Van's today, so I spent what little shop time I had this evening assembling the pedal assembly and test-fitting the Matco MC-5 master brake cylinders I plan to install. The MC-5s have reservoirs built right in, negating the need for a firewall-mounted reservoir and the associated brake lines that must be run. This evening, I just wanted to see how everything will fit together. The shafts of the MC-5s have different types of mounting holes than the stock brake cylinders, so the installation will obviously require some slight re-engineering.
Initial assembly of the flight-adjustable rudder pedal assembly.
