Buck's RV-8
Date: 10-25-2007
Number of Hours: 2.40
Brief Description: Pedal access hatch
I finished the pedal access door today. First, I riveted the rest of the platenuts to the attachment ring, then re-primed the "outside" surface of the ring. Next, I dimpled the fuselage skin holes, then riveted the ring to the skin. Finally, I screwed the cover plate on.
I see one small place where I'll have to file the edge of the cover plate a tiny bit to maintain a perfect seam width, but other than that, the cover fits very well.
I know this was a relatively simple modification among all the others I've done (and will do), but I'm especially pleased with the way this one came out.
Cover plate and attachment ring. Cutout at top is to clear the NACA scoop.
Attachment ring, riveted to the fuselage skin.
Mine will not be the lightest RV-8 around, but it WILL be easy to service...
