Brief Description: L flap fairing; traffic watch antenna; misc.
In my limited time this evening, I scuffed and cleaned the L flap fairing, then dimpled all the attachment holes and primed it. Then I began dimpling the corresponding holes in the fuselage skin.
Next, I located and drilled the 5/8" hole in the bottom of the gear tower where the coaxial cable for the Monroy ATD-300 traffic watch unit will pass through.
Finally, I shot a little primer on the now non-existant hole under the flap fairing.
L flap fairing, dimpled.
At lower right is the hole in the gear "well" for the coax cable to pass through.
