Buck's RV-8
Date: 1-6-2015
Number of Hours: 5.50
Brief Description: Forward spar attachments
You know it's a good day in the shop when you end up using ALL of your tools to complete a task. Such was the nature of the job of attaching the forward spar attach angles. The right wing went fairly smoothly. I had it final-profiled, drilled, and bolted to both the fuselage and the wing in about an hour and a half.
Because I had elected to install my fuel lines and fuel selector quite a while ago, I was presented with a much more daunting prospect on the left wing. Everything was a challenge, but after using just about everything in my toolbox at least once, and fabricating several tools to help move things along, I got it all done. My back might need a day to rest, though...
The only jobs remaining on the attach-angles are to install the nutplates on the aft faces of the angles, cut the slot in the tank angles, and safety-wire the bolts. I'll do the first two jobs when the wings come off, and the third one when they are reattached permanently.
The completed right forward spar attachment (minus the nutplate on the back).
Drilling the left forward spar attachment angle.
