Brief Description: Wingtip internal fixtures and nav light reflectors
Since I haven't received my 3" fiberglass tape for the stiffener dowels yet, I did some other projects today.
1. Laid out the APRS unit, antennas, and power cable and decided on the associated wiring runs. Installed several zip-tie mounting bases inside the R wingtip and also on the right wing rib. Reorganized the wiring that is protruding from the R wing rib.
2. Traced the shapes of the nav light pocket onto cardboard, then transferred these tracings to a sheet of 0.020" aluminum.
The APRS GPS antenna connector will live between these two zip-tie bases.
Cardboard templates for the four wingtip light reflectors.
