Increased the bevels on the edges of the bottom wing skins in order to create a smoother transition between the two. Ran an edge roller along the edge of the outer skin to pre-bend it it slightly. Re-primed the beveled areas on both skins. Marked the bottom ouboard skin with Van's recommended riveting pattern.
Fitted, drilled, and dimpled the outboard access cover. Scotchbrighted edges, then primed and labeled inside of cover.
I beveled and primed the edge of the skins where they overlap.
Don't try to understand this. It's my shorthand code to guide me through the skin-riveting process.
An overall view of the bottom outboard wing skin, ready for riveting.
