Continued covering RIght wing. Hit the top cover with the iron one last time. Then gave it a 250 ironing to tighten up the fabric. Fitted and final cut the bottom cover. Glued the TE and LE spars so fabric will stick. Started to get all the patches and exit plates together for both wings. Lots of filing and sandpapering.
Bottom cover ready to iron the LE andTE so we can start then the root and tip can be glued.
